Ape purchase MPV 600
Hier kommt alles herein was woanders zur Ape P501, P601 nicht hinein passt
Nanonomads
Vorname: Steve
Ape Model: Mpv600
Beitrag von Nanonomads » Montag 7. Juni 2021, 03:12
I bought an MPV600. And I'm having trouble learning about it or finding out information about it. I see a lot of posts about the 601 and the 501 and I see you have forums for that, but nothing for the 600 or 500. What's confusing me is are they the same do I just read the post for the 601 and assume that works for the 600? Anyway if anybody chooses to help me I would appreciate it greatly
Nanonomads
Vorname: Steve
Ape Model: Mpv600
Re: Ape purchase MPV 600
Beitrag von Nanonomads » Montag 7. Juni 2021, 04:01
The other question I have is since there's so little mentioned about the 500-600 Ape's. Is it because they are unwanted, undesirable or unloved? Or were there fewer made? I'm just trying to understand what I've bought or a little more about this vehicle. Thank you
Urs1962
Vorname: Urs
Ape Model: P 500 V
Baujahr: 1985
Km-Stand: 54400
Beitrag von Urs1962 » Montag 7. Juni 2021, 09:10
Hello ??
The MPV 600 is one of the most beautiful Ape and is also much more fun with the steering wheel than the Ape with the handlebar. The MP 500 and 600 are similar, the 500 has less payload (500 kg) and only one headlight, the 600 then has the 600 kg payload and two headlights. I have a MP 500 V (a model which was built mainly for Switzerland) and have totally restored it.
What exactly do you want to know about the PV 600? You can find all relevant data on the net.
Greetings from Lake Constance, Urs
Nanonomads
Vorname: Steve
Ape Model: Mpv600
Beitrag von Nanonomads » Mittwoch 9. Juni 2021, 03:22
Well I think I need some help with the carburetor, and also suspension and the engine I just have a question are they the same as the 601? And by that I mean if I order for instance drive rubbers I think they're called do I order them for the 601? My carburetor issue is that my screw that sets the idle doesn't actually touch the flat slide even when it's turned in and I'm curious do I have the wrong idle adjustment screw or something else? And also the slide doesn't have a needle on the bottom of it that goes into the mains jet possibly that's how it's supposed to be?
Nanonomads
Vorname: Steve
Ape Model: Mpv600
Beitrag von Nanonomads » Mittwoch 9. Juni 2021, 03:23
Also the vibration dampening motor mounts. Do I order those for the 601 or are they specific to the 600 Thank you very much for your help
Urs1962
Vorname: Urs
Ape Model: P 500 V
Baujahr: 1985
Km-Stand: 54400
Beitrag von Urs1962 » Mittwoch 9. Juni 2021, 08:33
Hello ?
In which country do you live? Parts suppliers are two larger in Germany, you can find them on the net.
The engine mount rubbers are the same for many models, if you order some for the P 501/P601 or 600 they will fit.
The carburetor idle screw will probably be the wrong one, it must be able to lift the slide. Also there are Dell Orto carburetors without jet needle, depends on the type. On the side of the carburetor is the designation. You can also find Dell Orto on the net drawings and specifications.
Greetings Urs
Nanonomads
Vorname: Steve
Ape Model: Mpv600
Beitrag von Nanonomads » Donnerstag 10. Juni 2021, 03:14
Thanks for your reply I'm in the United States. I know I'm not the only Ape owner here but I don't think there's a whole bunch of us that's for sure
