My engine repair
- Anfänger
- Vorname: Andreas
- Ape Model: 25km ape 50
- Baujahr: 2016
Re: My engine repair
Only the transmission cables and reverse cable left, but can't get any of them loose, any tips?
- Anfänger
- Vorname: Andreas
- Baujahr: 2016
They are too tight o loosen
- kofewu
- Vorname: Wolfgang
- Ape Model: TL2T
- Baujahr: alt
- Setup: 50er
Pull these rings off.
- Anfänger
- Vorname: Andreas
- Baujahr: 2016
Thank you kofewu.
Now the intesting and quite scary begins.
- Anfänger
- Vorname: Andreas
- Baujahr: 2016
Is there a special grease I need to use in the engine? Or can I use a regular multipurpose grease?
Never use a multipurpose oil, only SAE 80 or 80W90 gear lube oil with GL4 specification.
- Anfänger
- Vorname: Andreas
- Baujahr: 2016
How do you remove this bearing?
- Scharnhorst
- Viel Schreiber
- Vorname: Patrick
- Ape Model: TL6T
- Baujahr: 94
- Farbe: preussisch blau
- Km-Stand: 13999
It is always the same. It is helpful to heat up the aluminium housing, if you wanto to remove or remount a bearing.
In some cases even the bearing falls of by its own, in most case you have to use some light force.
Use a heat gun.
Kind regards,
Patrick.
Use a heat gun.
Kind regards,
Patrick.
- Anfänger
- Vorname: Andreas
- Baujahr: 2016
Thanks Patrick it worked
Should I do the same with this crankshaft?
- Anfänger
- Vorname: Andreas
- Baujahr: 2016
I have tried to remove the crankshaft from the case but it's really stuck.
