Hello
I'm going to try to rebuild my motor when the temperature outside is warmer, in the meantime I'm trying to figure out what tools I need to buy for the removal of the bearings. What sizes of the extractor do I need?
Sorry for the English but I'm from Sweden and we don't have this great forum.
Bearing extractor
- fachapeist
- Vorname: Rita
Re: Bearing extractor
which bearing do you want to replace??
Rita
Rita
- Anfänger
- Vorname: Andreas
- Ape Model: 25km ape 50
- Baujahr: 2016
Isn't it two bearings you can't get out whiteout a tool.
BTW it's zapc80 motor
- Foren Legende
- Vorname: Friedhelm
Nearly korrect.Tthe two bearings for the two gear-shafts ( a ball. and a needle-bearung ) need a special tool to extract them out after warmin of the housing ( in german called Innenauszieher ), alternative many improvisation.
The main-bearing from the crankshaft needs for replacing a special tool too ( in german called Trennmesserabzieher ) - or improvisation too.
- Anfänger
- Vorname: Andreas
- Baujahr: 2016
Is this something I can use?
- fachapeist
- Vorname: Rita
that Looks good...if the Diameter of the parts on the bottom left is right
Rita
Rita
